Dear Sir/Madam,
I am on beginner level on PSoC® Development and Programming. I am searching a suitable development kit which can help me to learn and use later on in my application. Is it possible to use CY8CKIT-001 PSoC® Development Kit for haptic application (HMI) or any other suggestion?
Thank you in advance
Chauhan
Sensing Technologies
Hi Chauhani,
Our PSoC1 devices will not be able to handle 120V.
Sampath Selvaraj.
Hello Chauhan,
Haptics was supported in a few devices of our PSoC1 family. I have attached the datasheet of these devices. The IDE for these devices is PSoC Designer. Haptics support was done with a User Module, the datasheet for which is also attached.
As a final note, PSoC1 devices are a mature family, and hence support for them is very limited. Also, we do not have any kit which has a Haptics vibrator motor.
Sampath Selvaraj
Hi Sampath,
Thank you very much for your reply. As i wrote i am on beginner level and want to build a board for haptic aplication. For me is very important to have output 120 V by applying 12 V input range from Board. Also, important is to have user guide which can support me to programm it.
Is it possible to have 120 V output from your suggested Data sheet?
Thank you very much in advance
WIth Best Regards,
Chauhani
Hi Chauhani,
Sampath Selvaraj.
