Hi there,
I have installed modus toolbox 2.2 in my windows 8 PC and try to start a new application according to getting started guide. Select File > New > ModusToolbox Application. But there is no selection for me to choose the Board Support Package (BSP) as “CYBT-213043-MESH”.
See screen shots attached.
Please advise what file is missing in my PC. Thanks!
ispn:40214:1:0
l1:314:1:0
Were you able to see the project creator window (see the attached video) after the warning message?
Please check you have a good internet connection. MTB project creator should be able to access the github repo.
ModusToolbox software is not supported on 32-bit operating systems. It has been tested on the following:
◼ Windows 7 64-bit / Windows 10 64-bit
◼ macOS 10.x
◼ Ubuntu Linux 18.04 LTS and 20.04 LTS (Note ModusToolbox software requires libssl1.0.0, which is not provided in Ubuntu 20.04 for example.)
-Dheeraj
