Hi:
as I know, the CyBluetool can download the bt mesh firmware by the uart interface. I have carefully read the cybluetool user guide. however I still don't know how to use the Cybluetool to download the fireware.the fireware download steps as follows:
The tool provides a way for the user to download firmware onto a device via a 'Firmware Download' feature which can be
accessed from the 'Tools' menu on the menu bar.
In order to download a firmware onto a device, the tool need not be connected to the device in prior. The Firmware Download
interface provides options for the user to select the device and baud rate.
The user can select the files required for downloading the firmware onto the device. On selecting a BTP file, the tool looks for
information about the paths to the other files (minidriver, config and firmware file). If the paths to these files are provided, the
corresponding path fields are automatically populated by the tool.
If the user does not wish to use one of the files, it can be deselected. But at least one of config file or firmware file must be
provided for the firmware download to be executed.
The status progress of firmware download is displayed on the status bar. Any errors during firmware download are also
displayed here.
there are some files that need to be loaded to the CyBluetool download
1. BTP file: I don't know what is the BTP file and where I can get this file
2. Minidriver file: I don't know what is the BTP file and where I can get this file
3. Config file: I don't know what is the BTP file and where I can get this file
4. Filewire file: I think this is downloading xxx.hex
Hi Mandy,
Below are the tool available :
1. CyBluetool as you referred already. The file locations are same in WICED studio also. Let me know if you can't get the location
2. Cypress Programmer: refer https://www.cypress.com/products/psoc-programming-solutions
3. Chipload : refer Programming using ChipLoad.exe
Anjana
If you are using CYW20819 and Modus Tool box is installed,
BTP file - C:\Users\......\ModusToolbox_1.1\libraries\bt_sdk-1.1\components\BT-SDK\208XX-A1_Bluetooth\platforms\208XX_OCF.btp
Minidriver file - C:\Users\......\ModusToolbox_1.1\libraries\bt_sdk-1.1\components\BT-SDK\208XX-A1_Bluetooth\platforms\minidriver-20819A1-uart-patchram.hex
Config file - cgs file available in the same location
Firmware file - hex file of your application
Refer to appnote : AN226546 for the file format details. : https://www.cypress.com/documentation/application-notes/an226546-cyw20819-feature-and-peripheral-gui...
Anjana
Hi Anjana:
I use the CYW20735 and wiced studio 6.4 is installed.
I want to know if there is any other tool to download the firmwire by the uart.
thanks.
mandy
Hi Mandy,
Anjana
Hi Mandy,
1. If you double click and open Chipload.exe , it will flash back. You need to go to the folder location, open the command line and run the Chipload.exe in command prompt. And then follow the steps mentioned in Blog : Programming using ChipLoad.exe
2. 20735 will be able to program from CyProgrammer. I am not sure which 20735 mesh board you are referring. There is no Cy Mesh board available for 20735. We have mesh boards with 20819 chip.
3. In CyBluetool , please check the file locations are correct or not.
Anjana
Hi Anjana:
when I use Cybluetooth to download the firmware ,there are some errors.the detail error information is below:
how to solve this question
thanks
mandy
Hi Anjana:
When I use the cypress programmer to download fireware,there is also a error during the programming
01 18 14 00 02 04 00
Info : Download config successfully had written 249 bytes to address 0x0001A71B: 28 00 18 15 00 02 07 03 28 02 16 00 00 2A 16 00 02 02 00 2A 17 00 02 07 03 28 02 18 00 01 2A 18 00 02 02 01 2A 30 00 02 04 00 28 28 18 31 00 02 07 03 28 04 32 00 DD 2A 32 00 05 02 00 DD 2A 33 00 02 07 03 28 10 34 00 DE 2A 34 00 05 02 00 DE 2A 35 00 0A 02 00 02 29 40 00 02 04 00 28 0A 18 41 00 02 07 03 28 02 42 00 29 2A 42 00 02 02 29 2A 43 00 02 07 03 28 02 44 00 24 2A 44 00 02 02 24 2A 45 00 02 07 03 28 02 46 00 23 2A 46 00 02 02 23 2A 50 00 02 04 00 28 D3 7F 51 00 02 07 03 28 14 52 00 CB 7F 52 00 05 02 00 CB 7F 53 00 0A 02 00 02 29 00 FF 02 12 00 28 1F 38 A1 38 AD 82 35 86 A0 43 13 5C 47 1E 5D AE 01 FF 02 15 03 28 38 02 FF 1B 66 6C 08 0A 57 8E 83 99 4E A7 F7 BF 50 DD A3 02 FF 89 10 00 1B 66 6C 08 0A 57 8E 83 99 4E A7 F7 BF 50 DD A3 03
Info : Download config successfully had written 249 bytes to address 0x0001A814: FF 0A 02 00 02 29 04 FF 02 15 03 28 08 05 FF 26 FE 2E E7 09 24 4F B7 91 40 61 D9 7A 6C E8 A2 05 FF A9 10 00 26 FE 2E E7 09 24 4F B7 91 40 61 D9 7A 6C E8 A2 01 00 01 00 00 00 A5 6C 22 00 20 07 04 00 03 00 00 00 00 08 12 00 00 00 00 08 12 00 00 00 60 00 60 00 00 00 60 00 60 00 00 00 60 00 30 00 1E 00 00 08 12 00 1E 00 18 00 28 00 00 00 BC 02 07 00 30 00 30 00 1E 00 00 04 00 04 3C 00 90 01 20 03 30 00 30 00 1E 00 A0 00 A0 00 1E 00 00 08 00 08 00 00 00 02 01 01 65 01 68 01 00 00 00 00 00 00 00 00 00 00 00 00 05 04 00 00 00 00 00 00 42 52 43 4D 63 66 67 44 4F BC 00 EE AA C8 D1 CC E4 D2 74 7D 08 44 C9 48 F6 C6 88 C5 EC 77 FE 50 1C 28 D6 A9 33 66 D0 60 51 25 63 FC C2 CA B9 F3 84 9E 17 A7 AD FA E6 BC FF FF FF FF FF FF FF FF 00 00 00 00 FF FF FF
Info : Download config successfully had written 154 bytes to address 0x0001A90D: FF A2 EE 79 BE 95 4C 24 83 A6 6F BD 49 9C 79 99 46 59 EC 6B 2B 39 B2 45 28 20 56 D9 F3 94 2D E1 66 03 01 6C 1C 85 22 00 0E 48 0F 49 88 42 08 B5 02 D0 0E 4A E6 F5 C4 FA 0D 4A 0E 48 00 21 E6 F5 C7 FA 0D 4B 0D 4A 23 F0 0F 03 13 60 E1 F6 DC FE 10 B9 0B 4B 0B 4A 1A 60 E8 F7 E0 F9 0A 4B 0B 4A 1A 60 08 BD 1C 72 22 00 1C 72 22 00 30 06 00 00 CC 0C 00 00 50 78 22 00 3C 85 22 00 64 04 20 00 B0 07 28 00 34 38 28 00 F0 28 20 00 C9 FF 20 00 06 01 04 1D 85 22 00 FE 00 00
Info : Downloaded 0 code bytes ( 0.0%) and 108967 data bytes (100.0%). Verified 0 code bytes ( 0.0%) and 0 data bytes ( 0.0%). Current state: Terminated with error
Info : A total of 1 contiguous memory areas were filled:
Info : [00000000..0001A9A6] DATA (108967 bytes)
Info : CRC timeout while checking 108967 bytes starting at address 0x00000000
Error: in procedure 'program_device'
Error: at file "C:/Program Files (x86)/Cypress/Cypress Programmer/scripts/WICED-BT/kit_CYW920735Q60EVB_01.tcl", line 50
Info : program_device "C:/Users/YYWu/Documents/WICED-Studio-6.4/20735-B1_Bluetooth/build/mesh_vendor_specific_app-CYW920735Q60EVB_01-rom-ram-Wiced-release/mesh_vendor_specific_app-CYW920735Q60EVB_01-rom-ram-Wiced-release.ota.hex" "0"
Info : Downloading FW ...
Info : status=1
Error: cyp status: ERROR
Info : Program device failed
Error: C:/Program Files (x86)/Cypress/Cypress Programmer/scripts/WICED-BT/kit_CYW920735Q60EVB_01.tcl:50: Error: Download minidriver successfully had written 249 bytes to address 0x00220000
Hi Anjana:
when I open the chipload.exe and the chipload flashback. if this is a system compatibility issue,my computer system is win8.1
Hi Anjana:
when I use the cybluetooth to download firmware and the cybooltooth mentions some errors,the error information is bellow:
Hi :
as we know, the CYW20735 can download the firmware from the uart by the Cypress programmer , when I use the CYW920735Q60EVB-01 to connect the Cypress programmer,and the Cypress programmer can find the uart. when I use the CYW20735 BT MESH module to connect the Cypress programmer,however the Cypress programmer can't find the uart.
I use the HCI uart to connect the Cypress programmer and the baurd rate is 115200, and turn on hardware flow control.
