Nov 04, 2020
08:14 AM
Nov 04, 2020
08:14 AM
I am using CYBT-213043-MESH
hello, how can I save an array uint8_t data [6] = {'d', 'a', 't', 'a', 's', 'a', 'v', 'e'}; in flash memory?, and how can I read this data every time I need it?
05:45 PM
Nov 04, 2020
05:45 PM
You can use nvram APIs listed in wiced_hal_nvram.h. Below example shows how to use it. Please have a look.
Please note, the NVRAM IDs which are already used by Mesh Core and Model libraries can be seen in mesh_setup_nvram_ids () defined in mesh_application.c. Please avoid using the same IDs for the array.
-Dheeraj
