Hi all:
now I want to add a customer model that can control a step motor to the bluetooth mesh stack
detali demands:
1. it can control the step motor how many steps it runs
2. the software can save the motor position to nv
3. can support this model scene operation
thanks
Hi mawu_4270096,
Mesh spec allows the developer to create vendor specific models that are not defined in the Mesh model Specification. Also we have a snip app called mesh_vendor_specific_app which will demonstrate this feature. Helper Applications (MeshClient - Windows) will help you to Send vendor data for vendor models.
You can certainly use scene models (mesh_scene_server, mesh_scene_client) if you think it is appropriate for your logic which you are going to implement. mesh_vendor_specific_app supports scene operations. You can understand more details about scene models and states from https://www.bluetooth.com/specifications/mesh-specifications/ (Mesh Model Specification 1.0.1).
-Dheeraj
Hi mawu_4270096,
-Dheeraj
hello :
I have solved this question
Hi mawu_4270096It is a pleasure to hear from you. Thank you very much.
