Bluetooth SDK Forum Discussions
AcSp_4798551
25 sign-ins 10 replies posted 10 questions asked
Dear Sirs,
I am not able to compile my current project (TARGET:CYBT-413055-EVAL) anymore - no idea why. When building the following message occurs:
/bin/bash: g++: command not found
make[1]: *** [../mtb_shared/core-make/release-v1.5.0/make/core/build.mk:376: C:/Users/Achim/mtw/PFSLocatoriAP2/build/CYBT-413055-EVAL/Debug/.metadata/.plugins/org.eclipse.cdt.make.core/specs.o] Error 127
make[1]: *** Waiting for unfinished jobs....
make: *** [../mtb_shared/core-make/release-v1.5.0/make/core/main.mk:414: secondstage_build] Error 2
In the same IDE I have the "Empty_BTSDK_App". which is running through fine.
DheerajPK_41
Could you please share your project with us? We will try to reproduce the issue.
I hope, it is due to some issue in the makefile or project import. You can try copy your source files to the working empty btsdk app and try running.
-Dheeraj
DheerajPK_41
-Dheeraj
AcSp_4798551
Dear Dheeraj,
it setup a new project and copied the program files into it, and the compiler is now running through.
So, it can be said: The problem is solved but the reason is unknown
Thanks and Regards
Achim
DheerajPK_41
Thank you Achim for the information.
We will share this feedback with our development team. The latest Modustoolbox version is 2.3 which you can get from https://www.cypress.com/products/modustoolbox.  Kindly check it.
-Dheeraj
