Dear Sirs,
I am not able to compile my current project (TARGET:CYBT-413055-EVAL) anymore - no idea why. When building the following message occurs:
/bin/bash: g++: command not found
make[1]: *** [../mtb_shared/core-make/release-v1.5.0/make/core/build.mk:376: C:/Users/Achim/mtw/PFSLocatoriAP2/build/CYBT-413055-EVAL/Debug/.metadata/.plugins/org.eclipse.cdt.make.core/specs.o] Error 127
make[1]: *** Waiting for unfinished jobs....
make: *** [../mtb_shared/core-make/release-v1.5.0/make/core/main.mk:414: secondstage_build] Error 2
In the same IDE I have the "Empty_BTSDK_App". which is running through fine.
ModusToolbox Bluetooth SDK
Could you please share your project with us? We will try to reproduce the issue.
I hope, it is due to some issue in the makefile or project import. You can try copy your source files to the working empty btsdk app and try running.
-Dheeraj
-Dheeraj
Dear Dheeraj,
it setup a new project and copied the program files into it, and the compiler is now running through.
So, it can be said: The problem is solved but the reason is unknown
Thanks and Regards
Achim
Thank you Achim for the information.
We will share this feedback with our development team. The latest Modustoolbox version is 2.3 which you can get from https://www.cypress.com/products/modustoolbox. Kindly check it.
-Dheeraj
