Bluetooth SDK Forum Discussions
daba_4649501
Greetings all,
     i need help with CYW989820EVB-01 development kit debug configurations.i am using MODUS TOOL BOX IDE for running the application. i connected the kit via usb port in my pc through PUART port , but i cant seem to enter the debugging mode or run. Please help me out...thanks a lot
Hi Danny,
Unfortunately that option of debugging via USB is not available.
Only option is to print the PUART logs for debug other than JTAG debug.
Anjana
AnjanaM_61
First comment on KBA 5 questions asked First question asked
thanks for the reply..i read the document that you sent me but it only has debug configurations for OPEN OCD and SEGGER JLINK modules. I only have USB interface to the evaluation board. can i debug only using pc via USB cable without using JTAG AND OPEN OCD?...i understand it says about hardware debugging interface but i cant able to configure it. please tell me how to debug only using USB cable and kindly share the step by step process if you can from build process and debug configs and environment variable paths and how to enable debug. Thank you!!!
regards,
Danny.AnjanaM_61
Hi Danny,
Anjana
Thank you, I will use segger-JLINK to debug the code. if i face any problems ,i let you know.
thanks for the support.AnjanaM_61
regards,
Danny
Sure !
Anjana
