Bluetooth SDK Forum Discussions
anje_2248446
25 sign-ins 10 replies posted 10 questions asked
Hello Cypress,
I have cyw20719b2 SDS Sleep configuration with TRASNPORT / NO_TRANSPORT mode. Device goes to SDS Sleep correctly. But after around 3 minutes in SDS Sleep device gets hard/cold reset, this issue is observed if BLE Advertising is turned off just before allowing SDS Sleep. If BLE Advertising is not turned off, then issue is not observed and device stays in SDS Sleep until there is a wake up triggered from gpio interrupt.
BLE advertising interval is set to infinite (set to 0).
I just want to confirm if it's possible to keep ble advertising off in SDS Sleep ? OR it is mandatory to keep ble advertising on when device is put in SDS Sleep ?
Aniket Jesu
DheerajPK_41
Moderator 750 replies posted 500 likes received 500 replies posted
Hi Aniket Jesu,
I can see that this issue is internally fixed, but the fix is still not available in the latest SDK because it needs more internal testing from our validation team. Hopefully, the fix will be available in the next SDK.
-Dheeraj.P.K
DheerajPK_41
We have observed similar issue previously.
Could you please share your project.  Let us check the project and get back to you.
-Dheeraj.P.K
anje_2248446
Hello @DheerajPK_41 Thanks for the reply.
Please find attached project as requested.
Aniket Jesu
anje_2248446
@DheerajPK_41 any update please ?
anje_2248446
@DheerajPK_41 Can you please let me know if there are any updates on the issue reported ?
Aniket Jesu
DheerajPK_41
Hi Aniket Jesu,
-Dheeraj.P.K
