- Email to a Friend
I tested 20719 audio_watch demo.
It can be successfully paired and connected with Bluetooth speakers.
However, when the Bluetooth speaker initiates a connection to 20179 (such as automatic reconnection when starting up), it is always unsuccessful.
There should be L2CAP connection request after "HCI_Encryption_Change", but in fact there is nothing.
Attach hci trace files, from BTSPY
ModusToolbox Bluetooth SDK
- Email to a Friend
HI @lei
Can you please let us know the steps you follow to reproduce this issue? Are you using default watch example or modified one ?
Can you also provide us the details about the Bluetooth speaker which you are using?
Anjana
- Email to a Friend
HI
I used default watch example.
Use ClientControl discovery BR/EDR - AV Source connect - Disconnect - Restart the Bluetooth speaker to automatically connect to the previous device - Can't connect
702--Self developed product, A2DP sink based on Qualcomm qcc3007 chip(connect to mobile phone OK)
MI18--Xiaomi Xiao ai Bluetooth speaker
Airpods has another problem,L2CAP connect successful but "SET CONFIGURATION" rejected.
