in the WICED BT SDK v3.1 I see a call back defined for the SPP BT Tx being completed:
wiced_bt_spp_tx_complete_callback_t WICED CYW208XX: SPP Library API (infineon.github.io)
Call backs for BT up/down/failed/rxdata are configured in:
wiced_bt_spp_reg_t WICED CYW208XX: wiced_bt_spp_reg_t Struct Reference (infineon.github.io)
but I cannot see where the wiced_bt_spp_tx_complete_callback_t is configured.
ModusToolbox Bluetooth SDK
I do not see it is used anywhere.
I hope there is a need of a code clean up.
-Dheeraj.P.K
-Dheeraj.P.K
so it is redundant and should no longer be in the code base?
Yes. I believe so. We will remove it.
We will discuss it internally. Please let us know if it is blocking anything in your development.
