When to set Tx Power CYW920819EVB-02
tho_ka
First like received 5 sign-ins First reply posted
I would like to reduce my Tx Power after establishing my connection to a central device in order to reduce the current consumption to a minimum.
However, I am not quite sure at which point I should call the API. I have already tried different points within the program.
I am calling it like:
wiced_bt_set_tx_power(NULL,-16);                   %NULL is stated in the API description as bd_addr
I always get the Return Value 8109 (WICED_BT_ERROR).
I have already implemented the wiced_bt_dev_set_adv_tx_power and it works perfectly fine!
Thank you in advance,
BR Thomas
SheetalJ
First comment on KBA 750 replies posted 500 likes received
Hi @tho_ka ,
You will need to give the BD address of connected device as first parameter of API wiced_bt_set_tx_power.
* Function Name: wiced_bt_set_tx_power
* Commands to set the TX power on link
* \param[in] bd_addr peer address to set ADV TX power keep bd_addr NULL
* \param[in] power power value in db
* \return wiced_result_t
wiced_result_t wiced_bt_set_tx_power ( wiced_bt_device_address_t bd_addr, INT8 power );
Above is the description of the API, can be found in wiced_bt_dev.h.
You should use this API after connection is established.
wiced_bt_dev_set_adv_tx_power () is used to set the advertisement Tx power.
SheetalJ
Hi @tho_ka ,
tho_ka
Hey @SheetalJ ,
Thank you very much, I must have misread that like 50 times. This has solved my issue!
BR Thomas
SheetalJ
For 8109 error-
Please use wiced_bt_ble_set_adv_tx_power() API to set adv tx power. The documentation for wiced_bt_set_tx_power() needs to be updated to remove the line that says setting BD ADDR null will update adv tx power. We will fix this in next BTSDK version.
