Bluetooth SDK Forum Discussions
marzuniga845
Hello all,
I have the CYBT-213043-MESH kit, and I have the CY8CKIT-005 MiniProg4 Program and debug kit.
I have connected the debugger (SWDIO pin) to the mesh kit (SWDCK pin) while both connected to my Mac.
I have set the ENABLE_DEBUG?=1 in the appropriate makefile of the application I wish to download onto the board.
My problem is that when I try to launch the debug, I get this error:
* KitProg firmware is out of date, please update to the latest version (2.21.1005)
* using fw-loader tool which can be found in the following folder
* /Applications/ModusToolbox/tools_2.3/fw-loader
I believe that I need to run this commands below, but I am not sure where the appropriate command line is. And if on terminal, which directory do I need to be in for this to work?
[install_path]/fw-loader/bin/fw-loader
--update-kp3 CY8CKIT-005
DheerajPK_41
I hope you have already seen the kitprog3 user guide. If not please see below link.
https://www.cypress.com/documentation/development-kitsboards/cy8ckit-005-miniprog4-program-and-debug...
fw_loader tool can get from below link. Please follow the instruction given in the readme.
vhttps://github.com/Infineon/Firmware-loader
https://github.com/Infineon/Firmware-loader/releases
-Dheeraj
DheerajPK_41
-Dheeraj
