Hi!
Thank you in advance.
I am trying to implement the application versioning info to my device ( AIROC CYW20719B2 chip).
Following the cypress doc for SOTA FW UPGRADE.
Secure Over-the-Air Firmware Upgrade (cypress.com)
as mentioned in section 6.1 for application versioning.
Couldn't store or update the app info,
1. Receiving compilation error when adding the piece of code as per doc sec6.1
error: unknown type name 'PLACE_IN_APP_ID_AREA'
51 | PLACE_IN_APP_ID_AREA wiced_bt_application_id_t mighty_vibe_app_id =
Kindly provide me solution to fix this.
2. what and where exactly it means PLACE_IN_APP_ID_AREA as per doc sec 6.1 ?
3. I used sdk api (wiced_firmware_upgrade_store_to_nv) to manually store
the app info in nv address location.
4. Also I didn't find any handle/API that provides my application the Active DS address location to store the App info.
Need a fix asap to complete SOTA FW UPGRADE with app versioning information.
Thank you.
ModusToolbox Bluetooth SDK
Hi @Nelson_J3010 ,
Looks like you are referring an older version of the document. The latest version of the document (BTSDK 3.2) can be found here :
In the latest BTSDK, the version ID related information is part of the makefile as expalined in the above app note. The ID related information will be placed in the DS header section of the firmware image.
Let us know if this solves your issue.
Bragadeesh
Hi @Nelson_J3010 ,
Bragadeesh
Followed the latest SOTA firmware upgrade document ,
Application versioning Issue was solved.
Thank you.
