I'm trying to implement Bluetooth low energy secure connections out of band pairing with the CYBT-413055-EVAL board and NFC. Are there any code examples which shows how to configure this feature using the Bluetooth SDK? I can't find any in the associated examples.
I am not aware of an OOB example on CYBT-413055. You can check the wiced_bt_dev.h to get the supported APIs and definitions (Eg. wiced_bt_smp_oob_data_reply).
I got a document about OOB application which is implemented in PSoC4 Bluetooth chip. This can be used to learn the basic and project architecture.
-Dheeraj.P.K
-Dheeraj.P.K
