Hello
i have the kit with 4 CYBT-213043-MESH
I am using the vendor specificr code to send messages to other meetings through the MESH NETWORK
I want the board with the specific vendor code to read the voltage level of a 3.3v battery and send this battery voltage level message to other boards through the mesh network,
Do you have an example code to use?
We don't have a modified version of mesh_vendor_specific code to read and publish the battery voltage.
mesh_vendor_specific_app is an application which demonstrates how to implement custom (vendor) mesh model.
SIG has defined a Generic Battery model in the mesh spec. The implementation is demonstrated in mesh_battery_server/client under snip mesh category. (Link)
Please refer spec for more details. https://www.bluetooth.com/specifications/mesh-specifications/
-Dheeraj
