I would like to use Quad SPI Master with CYBT-413061-02 (CYW20721).
I plan to use the Modus Tool Box / Bluetooth SDK.
However, in the 20719/20721 Hardware Driver's SPI peripheral API, I can only find the Standard SPI setting.
I recognize that the 20719/20721 supports Quad SPI.
Why isn't there an API?
Hello @KeTa_1341526
Currently we do not have library support for Quad SPI. Please get in touch with our sales / FAE to discuss the business opportunity if you want to add this feature request.
Anjana
Hello @KeTa_1341526
Anjana
Hi Anjana,
Does it mean that Quad SPI master cannot be supported by CYW20719 / CYW20721 or the Module on which those chip are installed?
The datasheet states that Quad SPI is supported.
Is there a way to use Quad SPI without using the API?
Hello @KeTa_1341526
Currently there is no way to use Quad SPI as we don't have library support for the same.
Anjana
