Programmed project of CYBT-213043-MESH kit
KaNa_3391246
Distributor - Marubun (Japan)
10 solutions authored First comment on KBA 5 solutions authored
I got a CYBT-213043-MESH kit. And I turned on the power and saw the following behavior.
- Color LED flashes
- The temperature and illuminance values are output to the USB puart.
Where can I get a project for this program?
By knowing this project, I would like to deepen the understanding of this kit.
DheerajPK_41
Hi KaNa_3391246​,
Th default firmware (Color LED flash, Temperature, illuminance prints) on the MESH kit is used for evaluating the hardware on the manufacturing line before they are shipped out.
To develop bluetooth mesh application please install latest MODUS1.1 SDK and update it with BT-SDK1.3. You will be able to see few mesh code examples in the SDK which demonstrate important features of Mesh.
ModusToolbox BT_20819A1 SDK
ModusToolbox BT SDK 1.3
Remaining mesh applications can be downloaded from Github.
GitHub - cypresssemiconductorco/Code-Examples-BT-SDK-for-ModusToolbox: These examples demonstrate th...
For learning mesh, I would suggest you to start with  Getting Started with Bluetooth Mesh​ guide, Or,
Please watch How To Design With Bluetooth Mesh (Hands-On) if you prefer video lecture.
Other useful Links:
Helper application guide: MeshClient and ClientControlMesh App User Guide
Other supported documents: https://www.cypress.com/products/ble-mesh
Please refer to BT SIG Mesh Specification also - https://www.bluetooth.com/specifications/mesh-specifications
-Dheeraj
DheerajPK_41
Hi KaNa_3391246​,
Other useful Links:
-Dheeraj
KaNa_3391246
Hi Dheeraj-san,
Thank you for your response.
I understood the default firmware. Please tell me a little more.
After downloading the application I developed to the MESH kit and rewriting the firmware,
Is it possible to restore the default firmware again?
Kazuhito Natori
Hi Kazuhito Natori,
We are not releasing the default firmware along with the SDK release.
But you can definitely use the available APIs to build similar independent program to check and test the hardware.
Useful APIs are well categorized and documented in the document section of the SDK. (WICED API Reference (BT SDK 1.3))
-Dheeraj
