AlPr_4646536
5 replies posted 5 questions asked First like received
Hello, how are you, Cypress community?
I need your help.
I have created an application for the development kit CYBT-213043-02 and I have tried to program it using MiniProg4 . However, I get the following error:
what could be happening?
how to change from adapter_khz to adapter_speed?
thank you very much for everything
AnjanaM_61
First comment on KBA 5 questions asked First question asked
Hi AlPr_4646536 ,
Hope you know that you have to use HCI UART interface of CYBT-213043-02 for programming the module.
Can you please confirm how the HW connections are done with CYBT-213043-02?
Which GUI are you using ? or are you using Modus Tool box IDE ? Please confirm.
Anjana
AnjanaM_61
Hi AlPr_4646536 ,
Anjana
Hello AlPr_4646536 ,
Is this issue fixed ? or are you still facing any issue?
Anjana
