Pairing process for Handsfree code example on the CYBT-343026-EVAL
jlarkin
5 questions asked 5 sign-ins First question asked
Maybe I am tired but I dont see any documentation or posts on how the BT Module pairing is done. I've successfully downloaded the Handsfree code example but when resetting (or cycling power) I dont see the module showing up on my Andriod phone's Bluetooth scan. Is there anything about pairing?
AnjanaM_61
5 comments on KBA First comment on KBA 5 questions asked
Hi @jlarkin
Can you please confirm which example you are trying?
If you are trying Audio_Handsfree example, then you need to use client control to send various commands to do the test.
Please check readme file along with the example project for the steps.
Anjana
AnjanaM_61
Hi @jlarkin
Anjana
