PA/LNA settings for CYBT-483056-02 in Modus Tool box
KeTa_1341526
Distributor - TED (Japan)
10 likes given 10 likes received 5 likes given
We are developing CYBT-483056-02 with MTB2.2.
On CYBT-483039-02 with CYW20719B1, it was necessary to add the following settings in WICED.
https://community.cypress.com/t5/WICED-Smart-Bluetooth/CYBT-483039-02-documented-PA-LNA-control-inte...
Do I need to make similar settings when developing CYBT-483056-02 with MTB?
Should I set the output setting of CYW20719B2 to -2dBm (because PA / LNA is 22dBm) in order to obtain POUT of 20dBm?
* Refer: https://community.cypress.com/t5/Resource-Library/Change-List-CYW20719-B1-and-CYW20719-B2/ta-p/24641...
TK
This issue is handled in a technical case.
SheetalJ
First comment on KBA 750 replies posted 500 likes received
Hi TK,
I am checking this internally. Apologies for the delay. Will post answer for your queries asap.
KeTa_1341526
Is there an update?
TK
KeTa_1341526
The background to this question is as follows.
-In the design using CYBT-483039-02 (CYW20719B1) and WICED, it was possible to connect to the opposite terminal.
  At that time, PA / LNA is enabled according to the following.
-Using CYBT-483056-02 (CYW20719B2) and MTB, the above PA / LNA is also enabled, but I cannot connect to the opposite terminal.
  When I check the RSSI, there are variations, and I'm guessing that PA / LNA is not enabled.
Please tell me how to operate normally with the combination of CYBT-483056-02 and MTB.
TK
