AsRa_264661
Level 4
Level 4
50 replies posted 25 replies posted 10 likes received
Hi All,
Could not start debugging with CYW920819EVB-02 , Also could not use external Jlink debugger.  Installed latest ModusTool Box 2.0
Previously everything was working with ModusToolBox 1.0
Ashok R
AshokR
5 sign-ins First solution authored First question asked
Hi Ashok,
If you installed the ModusToolbox in custom path, please follow the steps to create debug launch configuration.
Make File Changes:
ENABLE_DEBUG?=1
CY_TOOLS_PATHS+=C:/ModusToolbox/tools_*      -->(it should point to your installer path)
Create new  Debug Configuration:
Update with Below String values.
And it should work. and suspend at
Ashok Ra
AshokR
Hi Ashok,
Make File Changes:
ENABLE_DEBUG?=1
Ashok Ra
