Leke_2156536
First question asked 5 sign-ins Welcome!
Hello support team.
I am evaluation the CYWCYW20735B1 and measure current consumption.
CYW20735 data sheet shows current consumption of HIDOFF is 1uA.
Which sample application do I use to measure HIDOFF current.
Is there any guide to measure current consumption at CYW920735Q60EVB-01 ?
DheerajPK_41
As per our marketing decision, we have decided not to support CYW20735  chip in the broad market. To get a better roadmap of it, and confirm this info, please contact our FAE/Sales team.
Coming to your question.
The datasheet provides the current consumption value without using an upper layer application. Those values are the highest/lowest possible current values. We have a public low-power application implemented for another chip. You can check that application and try to port it to the 20735 chip. Because APIs are almost the same.
https://github.com/Infineon/mtb-example-btsdk-hal-low-power
https://www.infineon.com/dgdl/Infineon-AN225270_CYW208xx_BLE_Low-Power_Guidelines-ApplicationNotes-v...
-Dheeraj.P.K
DheerajPK_41
-Dheeraj.P.K
