paog_4272626
First question asked
Hello Team,
Good Morning/Evening
I was trying to customize the MeshClient windows app. I grabbed the source code from the link below and tried to build it though Visual Studio
\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\MeshClient
I found that the example code is not fully intact and there are missing library files as reported by visual studio compiler.
This issue is easily replicatable and I am sure many have already reported.
I have also attached screen shots as report by visual studio along with this issue. Can some one help me with work around for this.
Pavan
Severity Code Description Project File Line Suppression State
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\access_layer.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\core_aes_ccm.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\directed_forwarding.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\directed_forwarding_ctrl_msg.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\directed_forwarding_msg.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\directed_forwarding_timer.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\ecdh.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\foundation.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\foundation_cfg_model.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\foundation_crt_msg.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\foundation_heartbeat.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\foundation_identity.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\foundation_msg_handler.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\friend.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\friendship.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\health.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\iv_updt.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\key_refresh.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\lower_transport_layer.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\low_power.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\mesh_core.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\mesh_event.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\mesh_util.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\network_layer.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\pb_transport.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\provisioning.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_core_lib\upper_transport_layer.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_models_lib\generic_power_onoff_client.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_models_lib\remote_provision_server.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_models_lib\mesh_gatt_client.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_models_lib\fw_distributor.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_models_lib\generic_default_transition_time_client.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_models_lib\generic_level_client.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_models_lib\generic_onoff_client.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_models_lib\generic_property_client.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_models_lib\light_ctl_client.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_models_lib\light_hsl_client.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_models_lib\light_lightness_client.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_models_lib\mesh_model_utils.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_models_lib\object_transfer_client.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_models_lib\sensor_client.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_provisioner_lib\mesh_config_client.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_provisioner_lib\mesh_fw_provider.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_provisioner_lib\mesh_health_client.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_provisioner_lib\mesh_provisioner.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open source file: '..\..\..\..\..\..\libraries\mesh_provisioner_lib\mesh_proxy_client.c': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\c1 1
Error C1083 Cannot open include file: 'platform.h': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\mesh_main.c 47
Error C1083 Cannot open include file: 'platform.h': No such file or directory mesh_libs C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\mesh_libs\bt_target.h 5
Warning C4996 'GetVersion': was declared deprecated MeshClient C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\MeshClient\MeshClient.cpp 87
Warning C4996 'ABI::Windows::Devices::Bluetooth::IBluetoothLEDevice::GetGattService': Use GetGattServicesForUuidAsync instead of GetGattService.  For more information, see MSDN. MeshClient C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\MeshClient\Win10Interface.cpp 152
Error LNK1104 cannot open file 'mesh_libs.lib' MeshClient C:\Users\dummy_user\ModusToolbox_1.1\libraries\bt_20819A1-1.0\components\BT-SDK\common\apps\snip\mesh\peerapps\Windows\MeshClient\LINK 1
DheerajPK_41
Hi Pavan,
This is a known issue and our development team is currently fixing it. We will update the source code on community and Github versions soon. Please let us know if you have any other concerns.
-Dheeraj
DheerajPK_41
Hi Pavan,
-Dheeraj
DheerajPK_41
Please get the the latest mesh peer applications from below links.
