Sep 30, 2020
06:12 PM
Sep 30, 2020
06:12 PM
Working with the CYW20719B2 chip / ModusToobox.
Is there a way to erase the application code from the internal flash (using the IDE or some other tool), so that the chip is back to it's 'Factory' state?
09:15 PM
Sep 30, 2020
09:15 PM
Hi ChCh_3584941
One way would be to program the device with an empty application. This will overwrite your previous application in the flash.
We also have an API wiced_hal_sflash_erase() which can be used to delete particular bytes in the flash. Please check wiced_hal_sflash.h for more details.
Also, you can try using 'Erase' option in Cypress Programmer.
