Hi
I'm trying to implement HIDOFF using GPIO.
It worked fine with WICED Studio 6.x.
However, it does not work well with ModusTollbox2.3 + BT SDK (3.0 / 3.1).
In the case of Modus, 20706 go to HIDOFF, but it wakes up after 5 seconds without GPIO operation.
For Example
wiced_hal_gpio_register_pin_for_interrupt( WICED_GPIO_BUTTON, NULL, NULL );
wiced_hal_gpio_configure_pin( WICED_GPIO_BUTTON,WICED_GPIO_BUTTON_SETTINGS(GPIO_EN_INT_FALLING_EDGE), WICED_GPIO_BUTTON_DEFAULT_STATE );
wiced_power_save_start(WICED_WAKE_SOURCE_GPIO, 0);
Please tell me the correct setting of HIDOFF for ModusToolbox/BTSDK.
I am testing with the CYBT-343026-EVAL01 board. GPIO uses P0.
Update:
The issue showed up in multiple versions of SDK unevenly. It will be solved in the upcoming BTSDK (v3.3).
