How to set limited inqury access code when inquiring BR/EDR devices.
HyJe_4673431
I want to search BR/EDR devices which use limited inquiry access code.
It seems like that setting 'mode' paramter in wiced_bt_dev_inq_parms_t to BTM_LIMITED_INQUIRY when calling wiced_bt_start_inquiry function is releated to inqury access code but I cannot find how to set limited inquiry access code.
I'm using CYW20719B2 and BT SDK v3.1.0.
Eric Jeon
AnjanaM_61
10 questions asked 5 comments on KBA First comment on KBA
Hi @HyJe_4673431
Can you please clarify the requirement? Are you looking for an example on how to use BTM_LIMITED_INQUIRY  mode? If then , below is an example usage:
wiced_bt_dev_inq_parms_t params;
wiced_bt_set_inquiry_mode (BTM_INQ_RESULT_EXTENDED);
params.mode = BTM_LIMITED_INQUIRY  ;
params.duration = xx; // depends on your application
result = wiced_bt_start_inquiry( &params, &hci_control_inquiry_result_cback );
WICED_BT_TRACE( "inquiry started:%d\n", result );
Anjana
Hi Anjana,
Thank you for your reply and example code snippet.
I want to set inquiry access code when doing limited inquiry.
As you know, IAC LAP can be 0x9E8B00 ~ 0x9E8B3F.
Eric
