- Email to a Friend
I'm trying to reset by software.
It is not working.
Can you explain why it doesn't work?
ModusToolbox Bluetooth SDK
- Email to a Friend
You do not have to reset the device in this way. If you are attempting for repairing, and the peer device is a new device, 20721 stack should allow it undergo the whole pairing process. Soft or hard reset is not a recommended if the device does not allowing for re-pair.
Could you please share me the IDE, SDK versions and the application which you use? Is it a custom app?
-Dheeraj.P.K
- Email to a Friend
I didn't get the question. Why did you use 0x200000?
Please let me know what is the user scenario to do the reset?
-Dheeraj.P.K
- Email to a Friend
After remove device, my board can't work to re-pairing and connect.
I need to reset my board.
At first time, I tried to jump to address 0x0. But it didn't work.
And I find follows document about cyw20719(I can't find 20721's memory layout). The link is https://community.infineon.com/t5/Resource-Library/CYW20719-Memory-Layout/ta-p/246353.
Despite that it is 20719, I re-try to reset with ram start address.
Thanks your interest.
- Email to a Friend
-Dheeraj.P.K
- Email to a Friend
I' sorry I'm so late.
I use eclipse included in modustoolbox 2.4, wiced_btsdk 2.6, Audio_Headset_and_Speaker.
Thanks for your efforts.
- Email to a Friend
I would suggest to use the latest SDK. BTSDK3.2.
Your SDK (2.6) is pretty old and not compatible with Modustoolbox2.4.
- Email to a Friend
OK, thanks
