How to program FW into CYBT-413055-EVAL (CYW20719) with ModusToolbox
AcSp_4798551
25 sign-ins 10 replies posted 10 questions asked
May be I am stupid, but I do not get a build firmware into this module.
It is just the out-of-the-box firmware on it, which makes SPP. I can see the data on the USB-serial port.
Does anybody can help me?
... BTW: which initial project is programmed on this module ?
Achim
DheerajPK_41
Did you follow the steps mentioned in Eclipse IDE for ModusToolbox Quick Start Guide
Please let us know if you can observe any errors while trying to download the program to platform.
Please check other user guides and documents in https://www.cypress.com/products/modustoolbox-software-environment
I am not sure what exact program comes with the board by default. If it is having some firmware by default, it would be some peripheral demo firmware.
-Dheeraj
DheerajPK_41
-Dheeraj
Thanks Dheeraj - sometimes "I do not see the forest because there are too many trees in the way." - Germany wise.
