Hello
I have a cybt-213043eval and a cybt-213043-mesh board
I want to know how I can load the examples of Modus Tool box, Empty_213043EVAL, Empty_213043EMESH, Hello sensor etc etc on the 2 cards instead of OTA or another way that does not use UART
Other Technologies General
- OTA cybt-213043
For first time programming , you need to use HCI UART interface. There is no other option.
If you enable OTA in the application loaded via HCI UART, then next time you can use OTA for FW upgrade.
Anjana
Anjana
very good, already load the example: ota_firmware_upgrade, through hci uart
but now I want to load the empty code, or hello sensor, or beacon etc etc
how can I do this?
What are the steps?
how can I do this?
What are the steps?
Due to technical glitch in the community, I think we missed your query. Sorry for the inconvenience caused.
For OTA upgrade, you can collect the "__.ota.bin" after building the application from the SDK (.ota.bin file will be available inside build folder) and use any OTA peer app (https://github.com/cypresssemiconductorco/btsdk-peer-apps-ota) to do the upgradation.
Make sure that the chip is already having a firmware which can accept the OTA (eg. ota_firmware_upgrade).
-Dheeraj
