WaSe_1778651
10 replies posted 50 sign-ins First solution authored
Dear Infineon team,
I'm using the 89820 in my project. And I found some weird things in my project.
And I use the hello sensor application.
I found the device name of the GAP can have the write permission in the Bluetooth spec.
So I want to add that in my project but that is not working fine.
//BEFORE
    // characteristics of GAP service
    PRIMARY_SERVICE_UUID16( HANDLE_PHUB_GAP_SERVICE, UUID_SERVICE_GAP ),
// Declare mandatory GAP service characteristic: Dev Name
CHARACTERISTIC_UUID16( HANDLE_PHUB_GAP_SERVICE_CHAR_DEV_NAME, HANDLE_PHUB_GAP_SERVICE_CHAR_DEV_NAME_VAL,
UUID_CHARACTERISTIC_DEVICE_NAME, LEGATTDB_CHAR_PROP_READ, LEGATTDB_PERM_READABLE ),
//AFTER
// Declare mandatory GAP service. Device Name and Appearance are mandatory
UUID_CHARACTERISTIC_DEVICE_NAME, LEGATTDB_CHAR_PROP_READ|LEGATTDB_CHAR_PROP_WRITE, LEGATTDB_PERM_READABLE|LEGATTDB_PERM_WRITABLE ),
I'm adding the green high-light line but I could not find my whole characteristics in the phone application. (even though pairing is done.)
Could you help me how to add the write permission to the device name characteristic?
Wayne
Owen_Zhang123
5 questions asked 500 solutions authored 250 sign-ins
As the spec says, if the device is discoverable, the device name should only be readable.
Owen_Zhang123
