Test case:
1. the keys of the previously paired headset have been deleted from memory
2. when turning on the headset, I get only the BTM_PAIRED_DEVICE_LINK_KEYS_REQUEST_EVT event
How do I connect the headset knowing only the address of the headset?
Please have a look at below thread :
For detailed explanation of setting pairing & bonding of BT classic , I would suggest you to go through our CypressAcademy document and examples available here:
https://github.com/Infineon/CypressAcademy_BT101_Files/tree/master/PDFs (Refer WBT101-06A-ClassicBluetooth-Basic.pdf )
Anjana
Anjana
