Hi all!...after downloading and successfully installing the Modus Toolbox IDE I am having trouble to connect my Windows-10 pc with the Cypress EZ-BT MESH EVALUATION KIT...SEEMS MY COMPUTER IS UNABLE TO LOCATE THE RIGHT USB SOFTWARE DRIVER: not on my pc nor the Internet.
Any one have had the same issue/s before?...and then succeeded in solving it/them??....
Thanks in advance for any help and/or suggestion/s in this regards!
Daniel Corte.
ispn:40214:1:0
l1:314:1:0
On my PC, when I plug in the mesh kit, there is a USB-Serial (Dual Channel) with yellow bang. But also 2 new COM ports (WICED HCI UART and WICED Peripheral UART). If you have the same behavior, just ignore the yellow bang. 2 COM ports is all you need.
Could you try to install the USB driver and try again: https://www.cypress.com/documentation/software-and-drivers/usb-serial-software-development-kit
