ERROR:Failed to create and export "Empty_BTSDK_App_3" application
abhipsita
25 sign-ins 5 questions asked 5 replies posted
Hi everyone,
I am beginner in modus toolbox. I am getting an error message while trying to build a new application using modus toolbox 3.0. I have attached the screenshot for the error message as it appears. How to resolve the issue ?
Papendu
ChristopherF_51
100 sign-ins 25 solutions authored 10 likes given
Hi Papendu,
The main error I am seeing is that the Project Creator tool cannot locate the tools_3.0 directory. By default, it should be located in ~/ModusToolbox/tools_3.0, where ~ is your user home directory. Where did you install ModusToolbox?
Sven_Wang
250 sign-ins 50 solutions authored 25 solutions authored
Hi @abhipsita
I tried to select the CYW20706 to create a same project. And succeed.
Could you please share more information? Such as which chip did you selected etc.
Sven
Hi Sven,
I selected kit: CYBT-353027-EVAL, MCU/SOC/SIP : CYBT-353027-EVAL, connectivity : CYW20706A2 for creating an empty BTSDK application.
Papendu
ChristopherF_51
Hi Papendu,
Hi Christopher,
I am using fedora33 and I kept the installation files in 'root/opt/' folder. As per your reply, do i need to keep the installation files in 'root/home/username/' ?. I will try this out and let you know.
Papendu
Hi Christopher,
On moving the installation files to 'root/home/username/', the error has been solved.
Papendu
ChristopherF_51
Glad to hear it! Sorry I was away and didn't reply to your previous message. Happy New Year!
