Bluetooth SDK Forum Discussions
HereturbiesWalt
5 sign-ins 5 questions asked First like given
I am having trouble with extracting a .tar.gz file and accessing its files on a docker image. I've tried looking around Stackoverflow, but the solutions didn't fix my problem... Below is my folder structure and my Dockerfile. I've made an image called modus.
Folder structure:
- modus
    Dockerfile
    ModusToolbox_2.1.0.1266-linux-install.tar.gz
Dockerfile:
FROM ubuntu:latest
USER root
RUN apt-get update -y && apt-get upgrade -y && apt-get install git -y
COPY ./ModusToolbox_2.1.0.1266-linux-install.tar.gz /root/
RUN cd /root/ && tar -C /root/ -zxzf ModusToolbox_2.1.0.1266-linux-install.tar.gz
I've been running the commands below, but when I try to check /root/ the extracted files aren't there...
docker build .
docker run -it modus
  root@e19d081664e4:/# cd root
  root@e19d081664e4:/# ls
  <prints nothing>
There should be a folder called ModusToolBox, but I can't find it anywhere. Any help is appreciated.
P.S I have tried changing ADD to COPY, but both don't work.
Rakshith
Hi @HereturbiesWalt
Can you please try running  tar -xvf ModusToolbox_2.1.0.1266-linux-install.tar.gz instead of tar -C /root/ -zxzf ModusToolbox_2.1.0.1266-linux-install.tar.gzand let me know if that works?
In case that does not work, can you please try extracting any tar file on your image to check if extraction works?
Thanks and Regards,
Rakshith M B
AlenAn14
500 replies posted 100 solutions authored 250 replies posted
Hi @HereturbiesWalt ,
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
Alen
