Hello @DheerajPK_41
I had posted a questions a few months back here: https://community.cypress.com/t5/ModusToolbox-Bluetooth-SDK/Device-wake-gpio-and-gpio-irq-with-the-s...
In that post you posted a answer saying if host is not in connection and want device to go to sleep we should select WICED_SLEEP_MODE_NO_TRANSPORT as sleep mode.
So, I just wanted to clarify, We are having a standalone application and host wake pin is not connected to anything. So we have to use WICED_SLEEP_MODE_NO_TRANSPORT as sleep mode or is it possible to use WICED_SLEEP_MODE_TRANSPORT as sleep mode even though host is not in the picture ? If yes can you point out to any example with such scenario ?
Aniket Jesu
Hello @Owen_Zhang123
I got the SDS sleep and wake with gpio button press working, also I have added the RTC configuration for coldboot and fastboot to verify the RTC time is retained after wake up from SDS sleep.
I have attached the working code here, in case if anyone needs it. As it is difficult to find working examples.
