I'm using a CY8CPROTO-063-BLE board. When I try to initialize the BLE ECO clock, Cy_BLE_EcoConfigure() returns CY_BLE_ECO_HARDWARE_ERROR. The proximate cause is a time-out waiting for the BLE_BLESS_MT_STATUS.BLESS_STATE bit to be set, at line 409 in cy_ble_clk.c.
I have previously had BLE working in both Central Device and Peripheral roles, on two different copies of the board, and both boards now display the same behavior, so it's unlikely actually to be a hardware error. It's almost certainly a configuration problem, but I have no idea where to start looking.
/* Wait for BLESS in ACTIVE state */
while(((BLE_BLESS_MT_STATUS & BLE_BLESS_MT_STATUS_BLESS_STATE_Msk) == 0U) && (timeout > 0U))
timeout--;
Cy_SysLib_DelayUs(CY_BLE_DELAY_TIME);
if(timeout == 0U)
status = CY_BLE_ECO_HARDWARE_ERROR;
Any suggestions would be appreciated.
-Nick
Poking to keep post alive.
Do Cypress engineers still monitor this forum, or was that part of the change to the new platform?
Well, this is entertaining. The Cypress forum-bot has detected that my question has received replies, and helpfully suggests that I mark one as correct. I'll leave this as this week's poke.
Hello, sorry you haven't received a response. I have escalated this to the Modus Toolbox team.
Could you please let me know when you are calling this Cy_BLE_EcoConfigure() API in the firmware ? Do not call this API if the BLE is executed with LPM. There is a risk that when the Cy_BLE_EcoConfigure() function is called on one core, the BLE is in Deep Sleep mode on the other core. It will cause a fault hard exception.
If possible, please share your project so that we can check at our end.
P Yugandhar.
Hi @Yugandhar.
Thanks for the reply. I'm not calling Cy_BLE_EcoConfigure() directly. It's called from within cybsp_init(). The call stack is
cybsp_init() -> init_cycfg_all() -> init_cycfg_system() -> Cy_SysClk_AltHfinit() -> Cy_BLE_EcoConfigure().
cybsp_init() is executed by the CM4. The CM0 is in Deep Sleep mode when this happens, but it is at the very beginning of the initialization phase, and no library code has been executed. Besides, all BLE code in my project runs on the CM4 processor.
It would be difficult to provide a complete project, but could be done if there's no other way to debug this.
Thanks again,
-Nick
(sigh) - Back to the weekly poke to prevent the thread being ignored to death.
If possible, could you please share your design.modus and BLE config files of your project ?
Please refer to the "BLE_Find Me" code example in the MTB and check if you are seeing any issues.
P Yugandhar.
Hi @Yugandhar.
Thanks. I've attached my design.modus and design.cybt files.
The BLE examples work normally, which only reinforces the idea that I've just misconfigured something.
-Nick
Poking to keep the thread alive while waiting for a response.
I have created a Technical support case, please share your complete project in the case so that we can check at our end.
P Yugandhar.
