AkSr_4325006
First like given
I'm trying to interface a different sensor using P12 ADC input to read analog value. The data rolls over after a certain value and tried to change range_max under wiced_bt_mesh_core_config_element_t of the ambient temperature example code. On changing this, provisioning on the app shows complete when I connect to Cypress BLE Mesh board but doesn't show up under Components(Android Application) to read the data. Am I missing something?
Thank you in advance
DheerajPK_41
Hi AkSr_4325006
I can see the default value for .range_max is 0xffff (decimal: 65535). What is the changed value which is given by you?
Could you share your code so that I can take a look at it and try to reproduce the issue at my side.
FYI.
.move_rollover: The move_rollover parameter determines the action when a maximum value is reached. If this
value is ‘true’ when the level reaches the maximum range, the level value rolls over to the minimum value;
otherwise, it stops at the defined maximum value.
-Dheeraj
DheerajPK_41
Hi AkSr_4325006
FYI.
-Dheeraj
