I have a CY8CKIT-062-WIFI-BT board and would like to read temperature values from another controller (ESP32 conroller+BME280Sensor), for example.
I use the standard UUIDs (Environmental Sensing Service 0x181a and then the characteristic properties temperature 0x2a6e, humidity 0x2a6F and pressure 0x2a6d). To learn, I use the examples from the ModusToolbox™ Software Training Level 3 - Bluetooth® (e.g. key_ch06_ex04_connect_notify). I don't want to control an LED, just read values.
The GATT database is on.
******************** Application Start ********************
******************** Read BLE Devices ********************
Bluetooth Stack Initialization Successful
Bluetooth Management Event: 0x16 BTM_LOCAL_IDENTITY_KEYS_REQUEST_EVT
Bluetooth Management Event: 0x0 BTM_ENABLED_EVT
Bluetooth Enabled
Local Bluetooth Device Address: 00:A0:50:1D:95:63
Commands:
? Help (this message)
s Start scanning and connect
S Stop scanning
d Disconnect
n Turn on Button Count notifications
N Turn off Button Count notifications
0...7 Control LED
r Read LED value
Bluetooth Management Event: 0x17 BTM_BLE_SCAN_STATE_CHANGED_EVT
High duty scanning.
scan_callback function
Device = 30:24:A9:1C:30:6B
Device = 14:CB:19:E3:C5:BE
Device = 24:62:AB:F1:F8:2A
Found Device "ESP32S_BME280" with BD Address: 24:62:AB:F1:F8:2A
RAW Data:
Len = 31 02 01 06 0E 09 45 53 50 33 32 53 5F 42 4D 45 32 38 30 02 0A 03 03 03 1A 18 05 12 12 00 40 00 BB
Scanning stopped.
Bluetooth Management Event: 0x14 BTM_PAIRED_DEVICE_LINK_KEYS_REQUEST_EVT
Bluetooth GATT Callback Event: 0x0
GATT_CONNECTION_STATUS_EVT
GATT_CONNECTION_STATUS_EVT: Connect BDA 24:62:AB:F1:F8:2A
Connection ID 32768
Bluetooth Management Event: 0xb BTM_PAIRING_IO_CAPABILITIES_BLE_REQUEST_EVT
Bluetooth Management Event: 0x20 BTM_BLE_CONNECTION_PARAM_UPDATE
Bluetooth Management Event: 0xd BTM_ENCRYPTION_STATUS_EVT
Encrypt status: 0
Bluetooth Management Event: 0x13 BTM_PAIRED_DEVICE_LINK_KEYS_UPDATE_EVT
Bluetooth Management Event: 0xc BTM_PAIRING_COMPLETE_EVT
Pairing complete: 0
I understand the process so far. Now the services should be read in and I can't get any further.
When I press r for read LED value, a ledHandler = 0x09u is used, where does this value come from (or cccdHandle = 0x0Cu;)?
If I use 0x181a (Environmental Sensing UUID) there is an error.
When I press n or r the following comes up
Bluetooth GATT Callback Event: 0x7
GATT_APP_BUFFER_TRANSMITTED_EVT
Bluetooth GATT Callback Event: 0x1
GATT_OPERATION_CPLT_EVT
p_event_data->operation_complete.status: 0x1
GATT operation failed with status: 1
I don't know how to contact the services to read the value. it works on the smarphone.
ModusToolbox Bluetooth SDK
Hi @HeDi_4635501 ,
You have to use the Bluetooth host stack library only. To get the events in the desired sequence you have to create a Bluetooth task and block/unblock it using a queue.
For example:
Bluetooth_task():
Do the app init;
Establish connection->add data (a number that indicates case for your task immediately after connecting) in your queue that will be used to block/unblock the task;
Switch (queue_data):
Case ‘1’ :
//do the service discovery, add next data to the queue
Case ‘2’:
// send read request after given time interval
//start the timer, once it expires, send the request
And so on.
Please refer to this example : https://github.com/Infineon/training-modustoolbox-level2-psoc/tree/master/Projects/key_ch03_ex03_que... to see how led task is unblocked whenever there is some data in the queue (or how the task remains blocked whenever the queue is empty)
You can map the data in the queue to the case number of the next objective as per your sequence (scanning->connection->discovery->read request)
Thanks and regards.
Advait Kulkarni
Hi @HeDi_4635501,
Can you please let us know which Api you used to read the temperature characteristic? If you want to read the characteristic by UUID, you need to use wiced_bt_gatt_client_send_read_by_type(). If you want to read by handle, then first you need to discover all the services, characteristics and note their attribute handle. Also please share the modified project to us for our review.
Bragadeesh
I work with ModusToolbox 2.4 and Bluetooth Configurator 2.5.
I got the examples from here: ModusToolbox™ Software Training Level3 Bluetooth® (https://github.com/infineon/training-modustoolbox-level3-bluetooth , key_ch06_ex04_connect_notify ).
The function wiced_bt_gatt_client_send_read_handle which is defined in the program code or under mtb_share/btstack/release-v3.3.0 in wiced_bt_gat.h.
I can't find any examples of a central GAP that reads and displays standard UUIDs such as the temperature UUID 0x2a6e. I try to understand the examples mentioned and to adapt what is not linked to me.
I programmed this on a Raspberry Pi and it works. It's very complicated on this board.
Hi @HeDi_4635501 ,
You need to use the 'wiced_bt_client_send_read_by_type' API, https://infineon.github.io/btstack/ble/api_reference_manual/html/group__gatt__client__api__functions... (please refer to this link for various APIs and the parameters they take). You have to initialize parameters for the uuid and length of the data received, by referring to the UUID type structure definition in the wiced_bt_types.h file. For example:
int16_t temperature_val;
wiced_bt_uuid_t uuid;
uint16_t len = 0;
uuid.len = LEN_UUID_16;
uuid.uu.uuid16 = 0x2A6E;
wiced_bt_gatt_client_send_read_by_type(connection_id, 0x1, 0xFFFF, &uuid, (uint8_t *)&temperature_val, sizeof(temperature_val), GATT_AUTH_REQ_NONE);
In the GATT operation complete event in main.c, acquire the data received from the server if the completion status is successful.
Advait Kulkarni
Sorry for the late info.
The information was very helpful. I've only now understood the difference between uuid and hadler. The sample program "key_ch06_ex05_discover" can only be understood if you understand the whole handling of BLE. I have tried to understand and adapt the program. Point 1 scan and connect (via the controller name) is understandable.
Reading in the temperature after the last solution does not work.
Started temperature read service. Status: 0x0
Bluetooth GATT Callback Event: 0x1 GATT_OPERATION_CPLT_EVT
GATTC_OPTYPE_READ_HANDLE
temperatue value is: 0.00 ° C
If I first read in the temperature via a handler, then the last solution also works.
temperatue value is: 24.79 ° C
I need to call this function first
wiced_bt_gatt_client_send_read_handle(connection_id, tempHandle, 0, (uint8_t *)&tempValue, sizeof(tempValue), GATT_AUTH_REQ_NONE);
and then I can also use this funtion
wiced_bt_gatt_client_send_read_by_type(connection_id, 0x1, 0xFFFF, &uuid, (uint8_t *)&tempValue, sizeof(tempValue), GATT_AUTH_REQ_NONE);
read the value.
The cause is that the 2nd function in GATT_OPERATION_CPLT_EVT always goes into the first if statement.
p_event_data->operation_complete.op 0x2
why
Result is notified using GATT_OPERATION_CPLT_EVT of wiced_bt_gatt_cback_t, with wiced_bt_gatt_operation_complete_t::op set to GATTC_OPTYPE_READ_BY_TYPE
and the function doesn't do that
I have a second question.
I would like to display the content of the characteristic user descriptor 0x2901. All, temperature, humidity pressure have a descriptor. How do you do that the Zut temperature is displayed. All this is not a problem on the smartphone, but it is when programming. thank you for your help
Hi @HeDi_4635501 ,
1st query: The stack is developed in a way that the data is received in read handle event only even when you send a read by type request.
2nd query: The following is the code to read the characteristic user descriptor:
char *f;
uuid.uu.uuid16 = 0x2901;
wiced_bt_gatt_client_send_read_by_type(connection_id, 0x1, 0xFFFF, &uuid, (uint8_t *)&f, sizeof(f), GATT_AUTH_REQ_NONE);
Advait Kulkarni
Thank you again and again, because I would not be able to get this with the descriptions alone.
This means that the description in the Bluetooth Host Stack Library is wrong
Result is notified using GATT_OPERATION_CPLT_EVT of wiced_bt_gatt_cback_t, with wiced_bt_gatt_operation_complete_t::op set to GATTC_OPTYPE_READ_BY_TYPE.
How can I differentiate now?
case GATT_OPERATION_CPLT_EVT:
if (p_event_data->operation_complete.op == GATTC_OPTYPE_READ_HANDLE)
printf("GATTC_OPTYPE_READ_HANDLE\n");
if (p_event_data->operation_complete.response_data.handle == tempHandle)
printf("temperatue value is: %4.2f \xb0 C\n",tempValue/100.0);
else if (p_event_data->operation_complete.response_data.handle == humiHandle)
printf("humitity value is: %5.2f %%\n",humiValue/100.0);
else if (p_event_data->operation_complete.response_data.handle == pressHandle)
printf("pressure value is: %.2f hPa\n",pressValue/1000.0);
else if (p_event_data->operation_complete.op == GATTC_OPTYPE_READ_BY_TYPE)
printf("GATTC_OPTYPE_READ_BY_TYPE\n");
Even with your second answer I get into the GATTC_OPTYPE_READ_HANDLE. How do I say what I want to show now?
Hi @HeDi_4635501 ,
We will update the description in the Bluetooth host stack library regarding the data being received in read handle event irrespective of the request being read handle or read by type.
If you have done service discovery, then you will know which handle corresponds to which data. However, if you have not done service discovery and sending a request using a UUID, the data with that particular UUID only will be received, hence, it is expected that you know which data you are requesting for, while using read by type.
You can refer to the bluetooth spec core v_5.3>Host>ATT>Protocol requirement>Attribute protocol PDUs>Reading attributes
for more clarity on read by type and read handle.
Once you have requested for some data (say temperature), you have to wait till you receive some response before sending another request (say humidity). Thus, you can know what value you have received.
Advait Kulkarni
if i use the function wiced_bt_gatt_client_send_read_by_type the temperature 0 is displayed.
output:
Gatt Event Complete Conn=32768 Op=2 status=0x0 Handle=0x2A len=2 Data=A8 08
Temperatue value is: 0.00 °C
what is wrong or who writes a value in the variable tempValue
Hi @HeDi_4635501 ,
The tempvalue is used only for values that are greater than the maximum transmission unit's (MTU) size limit (refer to the parameters under the wiced_bt_gatt_client_send_read_by_type() API on this link: https://infineon.github.io/btstack/ble/api_reference_manual/html/group__gatt__client__api__functions...).
Here, you have to use the attribute data, for example,
data = p_event_data->operation_complete.response_data.att_value.p_data;
printf("%f\n",data);
Also, since you are using UUID (read by type API), you do not need to check the response_data.handle. Without service discovery, the client will not know which handle corresponds to which data.
Thank you and regards,
Advait Kulkarni
the BLE programming on the Cy8Ckit-62-WiFi-BT with mode toolbox is very complicated. The key_ch06_ex05_discover example is very specific and cannot be generalized.
I have 3 sensors (temperature, humidity and air pressure). The values are to be transmitted via Bluetooth. The board is the GAP Central or GATT Client.
Finding and connecting a BLE client works well.
Reading data from multiple UUIDs does not work. I don't think libraries can do that.
I will now show the services or characteristics.
. startServiceDiscovery();
. startCharacteristicDiscovery();
Now I know the corresponding handles.
********************** Read BLE Data ***********************
Bluetooth Enabled
High duty scanning.
[4090] wiced_post_stack_init_cback(): BT sleep mode is NOT enabled
Scanning stopped.
Connection ID 32768
? for Help
Encrypt status: 0
Pairing complete: 0
? for Help
Started service discovery. Status: 0x0
UUID = 0x181a, attr handle: 0x0028, end grp handle: 0xffff
Started characteristic discover. Status: 0x00
charHandleCount = 0
Char Handle=0x0029 Value Handle=0x002A UUID: 2A6E
charHandleCount = 1
Char Handle=0x002D Value Handle=0x002E UUID: 2A6F
charHandleCount = 2
Char Handle=0x0031 Value Handle=0x0032 UUID: 2A6D
Start temp char descriptor discovery. Status: 0x00
Characteristics Descriptor Handle = 0x002B, UUID: 2901
Now I can look at the function wiced_bt_gatt_client_send_read_handle(connection_id, tempHandle, 0, (uint8_t *)&tempValue, sizeof(tempValue), GATT_AUTH_REQ_NONE); Read in temperature, humidity or air pressure values.
Gatt Event Complete Conn=32768 Op=2 status=0x0 Handle=0x2A len=2 Data=5a 09
Temperatue value is: 23.94 °C
Gatt Event Complete Conn=32768 Op=2 status=0x0 Handle=0x2E len=2 Data=25 0e
Humitity value is: 36.21 %
Gatt Event Complete Conn=32768 Op=2 status=0x0 Handle=0x32 len=4 Data=0c 87 0f 00
Pressure value is: 1017.61 hPa
? for Help
I have a problem reading the description of the sensors. It only works with the temperature. I do not know why?
Started startCharacteristicUserDescriptor, Status: 0x0
Gatt Event Complete Conn=32768 Op=3 status=0x0 Handle=0x2B len=23 Data=54 65 6d 70 65 72 61 74 75 72 20 2d 34 30 2e 2e 2b 31 32 35 c2 b0 43
Handle: 0x2b
Temperatur -40..+125°C
Only the 0x2B handler is used.
The call function:
static void startCharacteristicUserDescriptor( void )
/* val handle temp-2b, humi-2f, press-33 */
wiced_bt_gatt_status_t status = wiced_bt_gatt_client_send_read_by_type(connection_id, 0x0001, 0xffFF, &uuid, (uint8_t *)&descriptor, sizeof(descriptor), GATT_AUTH_REQ_NONE);
printf( "Started startCharacteristicUserDescriptor, Status: 0x%0X\r\n", status ); }
I don't know what to do here! Thanks for the help. there are many descriptions but reading in metrics from clients doesn't seem to be needed. I haven't found any examples (CTC client maybe).
Hi @HeDi_4635501 ,
This is happening because the user descriptors of each characteristics have the same UUID, which is 2901. Hence, when you send a read by type request, you receive only the one with the lowest HANDLE. (temperature user descriptor handle<other user descriptor handles). So, to get the next lowest handle, you must send another read by type request and update the starting handle in the "wiced_bt_gatt_client_send_read_by_type (uint16_t conn_id, uint16_t s_handle, uint16_t e_handle, wiced_bt_uuid_t *p_uuid, uint8_t *p_read_buf, uint16_t len, wiced_bt_gatt_auth_req_t auth_req)" to one more than the handle of the received descriptor. (For eg, the handle of temperature user descriptor is x, so, send another read by type request with starting handle as x+1, continue sending read by type requests with updated starting handles till you receive all the descriptors).
Alternatively, you can change the definition of read_by_type_handler at the server end in your project in a way that it sends all the handles of the requested type in a single read by type request.
I am sharing with you a server project which is an anycloud BLE environment sensing example. Please refer to the "app_gatt_read_by_type_handler" definition in the "app_bt_gatt_handler.c" file. Using this implementation, all the handles with same type will be sent in just one read by type request, by calling the GATT_OPERATION_CPLT_EVT each time till all the handles are sent. Also sharing the client project and the terminal output for reference.
Finally, since you have done the discovery and know the corresponding handles, you can just use the " wiced_bt_gatt_client_send_read_handle" API.
Thanks and regards,
Advait Kulkarni
Hi @HeDi_4635501 ,
To get the sequence that you want, you can create a Bluetooth task and inside this task, you can put all the Bluetooth code. You will need to use the "xTaskCreate" command in your int main. Please refer to the https://github.com/Infineon/mtb-example-anycloud-ble-capsense-buttons-slider (ble_task, capsense_task and led_task) example and the https://github.com/Infineon/mtb-example-btstack-freertos-hello-sensor (button_task) example to see how to create a task and how to synchronize it with a timer.
Thanks and regards.
Advait Kulkarni.
Hi @HeDi_4635501 ,
For example:
Bluetooth_task():
Do the app init;
Case ‘1’ :
Case ‘2’:
And so on.
Thanks and regards.
Advait Kulkarni
