Bluetooth SDK Forum Discussions
goonzo
First reply posted First question asked First like given
Currently our product solution is using SDK 2.9 and are waiting for an update to 3.0 to take care of some bug fixes.
We are about to start the qualification process and intend to refer to the prequalified components:
controller: https://launchstudio.bluetooth.com/ListingDetails/108621
bt stack: https://launchstudio.bluetooth.com/ListingDetails/120227
Will the stack get a new version with the new SDK 3.0  so that we need to qualify the entire stack?
or can we still refer to the prequalified 4.1 mentioned above?
regards
/Martin
Owen_Zhang123
500 solutions authored 250 sign-ins 1000 replies posted
The qualification you show is 5.2.
And the answer is yes,  you can still use the qualification when updated to btsdk3.0.
Owen_Zhang123
Thank you for the quick answer.
Since the controller is qualified for core 5.1, is it still ok to refer to the BT-stack 4.1(that is qualified for core 5.2)?
Does it matter that the stack supports core 5.2?
The complete design will only support core 5.1 anyway.
/Martin
Owen_Zhang123
It is OK to refer to the BT-stack 4.1.
