Bluetooth SDK Forum Discussions
MiLe_4471161
I use ModusToolbox IDE to program beacon example.
But it cannot work.
I can use WICED STUDIO IDE to program, but it doesn't work on ModusToolbox.
So I can confirm that the programming environment of the hardware platform should be no problem.
My EVK picture as below.
Can someone help me to clarify this issue?
SrikanthD_56
First comment on blog 100 replies posted 50 solutions authored
Looks like your version of the kit is not supported in ModusToolbox.
Cheers!
DheerajPK_41
Moderator 750 replies posted 500 likes received 500 replies posted
MTB supports CYW920719B2Q40EVB-01 (https://www.cypress.com/documentation/development-kitsboards/cyw920719b2q40evb-01-evaluation-kit )
The CYW20719 device and the evaluation kit are supported in ModusToolbox 2.0 (or later) and the BT SDK 2.0 (or later).
-Dheeraj
SrikanthD_56
Cheers!
