Is it possible to update FW via I2C or SPI instead of HCI UART or OTA for the CYBT-213043-02 module?
- cyw20819
Currently our SDK won't support this feature.
Anjana
Hi AnjanaM_61
What FW update processes are supported? I assume OTA is supported (since it is part of the marketing information).
John Battin
Additionally, my customer is running an Intel processor that is using Linux OS. Does the WICED SDK provide a Linux compatible firmware output or is their some way to port the firmware code into Linux?
They would need to leverage external host, or HCI mode. This means that a BT Stack like BlueZ would run on the Intel processor and talk to the device over HCI mode.
Putting 2073x, 2070x, and 20719 Based Devices or Modules in HCI Mode – KBA225450
In this mode, a basic set of HCI commands can be processed.
The BlueZ and Intel Processor would not be supported here on the community.
