ToKo_4602001
Level 4
Level 4
50 sign-ins 25 replies posted 25 sign-ins
Can I use the function wiced_bt_dev_set_link_policy() used in
wiced_btsdk\dev-kit\libraries\btsdk-audio\COMPONENT_bt_hs_spk_lib\bt_hs_spk_control.c ?
Seemingly there is no definition in header files.
Is there a method to permit or forbid role_switch and sniff?
AnjanaM_61
First comment on KBA 5 questions asked First question asked
Hi ToKo_4602001 ,
I am sorry , this API is not available for 20819.
I am checking these internally with our Software team along with your query here:CYW20819 SWITCH_ROLE
Anjana
AnjanaM_61
Hi ToKo_4602001 ,
Anjana
Thank you for your quick response.
Hi ToKo_4602001 ,
Currently these APIs are not included in SDK for CYW20819.
Our software team is working on this to fix in next BTSDK releases.
Sorry for the inconvenience caused.
Anjana
