Bluetooth SDK
MaCh_4826131
25 sign-ins 10 sign-ins 5 questions asked
I have a microphone connected to my CYW920819 board via i2s.
Unfortunately I am unable to get it to stream to my bt headphones via a2dp (is it even possible?)
I am using the watch example for this board and followed the blog below to route i2s.
https://community.cypress.com/t5/Resource-Library/PCM-I2S-Clock-setting-in-CYW20706/ta-p/246335?emcs...
Could it be a codec issue/sampling rate issue?
Any help would be greatly appreciated.
Thanks in advance!
SheetalJ
Moderator 750 replies posted 500 likes received 500 replies posted
Hi @MaCh_4826131 ,
Apparently I2S input feature on watch CE is supported only on CYW20721 platform. It is not possible to receive input using a microphone via a codec on CYW20819 over I2S.
