I am experiencing the problem that HCI event cannot be return correctly responded to HCI command sent to HCI_UART if our application firmware runs.
Of cource if the line below is commented out, the problem is resolved.
// wiced_bt_stack_init(bt_app_callback, init_cfg_param(), wiced_bt_cfg_buf_pools);
Is it possible to use HCI command (for RF test) at the condition that an application firmware is written.
Hi @ToKo_4602001 ,
The device should be in HCI mode in order to receive HCI commands. This is not possible when you load an application to the device with BT stack initialized.
Hi @ToKo_4602001 ,
Thank you for quick response.
