we are doing an ble mesh application using CYBT-483056-02. In the Vendor Specific example it is possible to set the tx power (wiced_bt_mesh_core_adv_tx_power) in the range 0-4 (5 steps). How does these 5 steps map into tx power in dBm?
Niels
ModusToolbox Bluetooth SDK
Hello @niels5750
Please find the test results from our HW team:
The following table lists CYBT-483056-02 “tx_power” with different “wiced_bt_mesh_core_adv_tx_power” value (0~4).
Application: Mesh_Snip_Vendor_Specific
wiced_bt_mesh_core_adv_tx_power |
0 |
1 |
2 |
3 |
4 |
Tx power (dBm) |
8 |
11 |
17 |
19 |
19 |
Note :
Please note that the value of TX power may be varied due to SMA connector soldering, cable loss difference, etc. 1-2 dB difference is reasonable.
Anjana
