Bluetooth SDK Forum Discussions
StN__1917156
Level 4
Level 4
How could use  examples given in BT SDK1.4 for CYW920719B2Q40EVB-01 Evaluation Kit  with CYBT-413034-EVAL board?
It is same chip CYW20719 minor differences in the pin outputs and installed peripherals ...
SheetalJ
Hi StN._1917156​,
CYBT-413034 has CYW20719B1 chip inside, whether as CYW920719B2Q40EVB-01 has CYW20719B2. Firmware inside ROM is different for both the chips, so you cannot directly program the examples given for CYW920719B2Q40EVB-01 to CYBT-413034-EVAL board.
However you can try implementing the same for CYBT-413034 by changing some APIs and functions seeing the availability for CYW20718B1.
SheetalJ
Hi StN._1917156​,
Actaully my module is CYBT-413034-02, I've search the spec sheet, but cant find anywhere what is the actual version of CYW20719 embedded there?
CYBT-413034-02 contains CYW20719B1.
