Hello There,
We are going to design using CYBT-413034 module. I think it will be the same as CYW20719
Anyway. Please kindly let me know the following issues.
1. DUT MODE entry method for BT TEST and BLE TEST method guide document
2. BT/BLE TEST control program
3. Authentication Firmware and Download tool
BR,
Tony Kim
Hi ToKi_1339406 ,
CYBT-413034 module uses 20719B1 as base chip. Its supported on WICED Studio SDK.
latest WICED SDK version is 6.4 - https://www.cypress.com/products/wiced-software
To use 20719 module in WICED 6.4, customer have to include the patches available here: Platform and New Patch Files For 20719B1 in WICED 6.4.0.61 - KBA228518
I would suggest you to go through Getting started appnote here to start using CYBT-413034 with WICED SDK : https://www.cypress.com/documentation/application-notes/an223400-getting-started-ez-bt-wiced-modules
A: For 1, 2 - please clarify your query. You want to test all BR/EDR , BLE functionalities or RF test ?
If RF test - you may refer blog - RF Testing on Cypress BT Devices - KBA228303
If for HCI commands test , the module have HCI UART port through which you can send & receive HCI commands . You can use CyBluetool for test purpose - CyBluetool (Windows Installer) CyBluetool User's Guide
A: You can use WICED SDK to develop and download user application.
We also have GUI available to download hex - WICED Module Programmer User Guide – KBA225060
Anjana
Hi ToKi_1339406 ,
Anjana
