Bluetooth SDK Forum Discussions
NeDh_4602711
50 replies posted 25 replies posted 25 sign-ins
I am trying to implement deep sleep using the wiced_power_save_start() function but it causes reboot the controller on wakeup after a given timeout. But this happens only once on startup, after that it keeps restarting without waiting for a timeout to occurs. Why So? That means if I want t put it on deep sleep mode (HID-OFF) for a given timeout, I have to hard reset the controller.
I have found this below in this document. I want to implement this PDS. Could you please help me? If you have any example can you please send it? or pls suggest me the changes to be made in HID-OFF code to change it to PDS.
Thanks in advance.
Thanks and regards,
Neeraj Dhekale
AnjanaM_61
First comment on KBA 5 questions asked First question asked
Hi NeDh_4602711​ ,
Have you gone through the example available here:
CYW20706 – BLE Low Power Beacon
Anjana
AnjanaM_61
Hi NeDh_4602711​ ,
Anjana
