CYBT-333047-EVAL + ModusToolbox Support
Yashu
Level 4
Level 4
25 sign-ins First solution authored 25 replies posted
This webpage claims that CYBT-333047-EVAL is supported by ModusToolbox:
https://www.cypress.com/products/airoc-bluetooth-le-bluetooth
But Github does not list this Eval Kit Target:
https://github.com/Infineon?page=1&q=TARGET_
Is this kit supported? and if so, is there an Audio Gateway Master w/ I2S stream example for the kit?
Yashu
Level 4
Level 4
Just like I figured... no Audio Gateway turnkey demo available for this module. You have to adapt the CYW20706 EVAL BSP to a CYBT-343026 EVAL and then use it. Also need to change default baud rate from 3Mbaud for FTDI on the CYW20796 to 115.2Kbaud for Cypress USB-UART on the 343026/333047 Eval kits. Plus need to turn off all switches on the PUART DIP switch to use the I2S bus.
SheetalJ
First comment on KBA 750 replies posted 500 likes received
Hi @Yashu ,
Module CYBT-333047-EVAL is CYW20706 based, therefore you will have to search for CYW20706 supported code examples for CYBT-333047 module. After selecting the code example in ModusToolbox, please change the target board using Library Manager.
Yashu
Level 4
Level 4
